well first and formost ... thank you sactown for the blower and i can't believe you sold it..... i feel like i stole it from ya, lol.
i would also like to thank GB10, 05Stroker, S&H, E85... a many others that i've bothered with questions and will continue to bother during this build. lol
i'm puting a new motor and sactowns blower in the car and adding a waste gate and boost controller so i can use the boost lower in the RPM and limit the max boost.
so far i have a big bore stock stroke 5.0 at 11.5-1 that was built by the SD Wheeler.... this block was passed down this board a couple times before i got it and it was near used. i did have the short block taken apart and everything checked and balanced just to make sure everything was ok.
link to original sale thread... http://www.s197forum.com/forum/showthread.php?t=70911
my heads are being ported and i'm using stock lash adjusters, stock followers, stock exhaust valves, SS intake valves, PAC springs, steel retainers, livernois lockouts, viton vavle stem seals, bronze guides.
cams are from bullet cams.... not sure of specs yet (open for input)
Cam profile suggested for 3.55 gears and good street manners with PAC spring and lock outs
@.050 duration intake 227 exhaust 243 lift 525 intake 525 exhaust LSA 114 CLA 110
running meth injection too
i'll update as i buy items....
Parts to be installed
Big bore stock stroke 10.7 to 1 or 11.5 to 1 compression
(i've been told a few different things from the original build to the person putting the engine together)
Big heavy wheels
Sactown F1R kit
Sactown Meth kit
Ported heads to match cams
Cams 227in 243ex @.050 lift 525 in and ex 114 lsa
Stock exhaust valves
Steel intake valves
PAC nitrate springs
Steel retainers
Stock lash adjusters
stock followers
BA500 MAF
GT500 TB
Ford Racing intake
Bosch 1000 injectors
WOT box
44mm waste gate
True boost controller
Edelbrock water pump
Excedy throwout bearing
Ram dual clutch 10 spline (with new flywheel)
Flowmaster outlaw mufflers
BMR sub frame connector
BMR K-member
Solid motor mount
BAP
that's all for now....
Big heavy wheels
Sactown F1R kit
Sactown Meth kit
Steel intake valves
PAC nitrate springs
Steel retainers
stock followers
BA500 MAF
GT500 TB
Ford Racing intake
WOT box
44mm waste gate
BMR K-member
Solid motor mount
BAP
