PLee
Give Jason at DOB a shout about the alternator project he's working on... OEM 200a alternator that a few people are already using, and it's completely bad ass. Will have mine up and running very shortly as well.
BTW- hell of a build!!!! You're bound to have some things to iron out after having replaced so much... but, don't let that frustrate you, just keep at it!
I may have some good news regarding another option for upgraded alternator!!!
I ordered a set of coils from Performance Distributors which are known for their DUI systems. Anyway, I contacted them and they said they can custom build a 240 amp alternator for our cars!! 120 amps at idle!!!
I am still investigating if this will be a bolt-on affair or if its a custom fab setup.
Pricing would be around $500 though...
Here is their current offerings:
http://www.performancedistributors.com/alternators-mramp.htm
If its more reliable and stable than the PA Performance, it may be worth it!!!
More to come!!
Does anyone know what is the minimum voltage our car need to perform nominally?
Right now, at full load, my voltage drops to 13.5 or so...thats reading at the battery which the voltage is slightly higher at the alternator output; typically 0.5 volts difference.
