few on3 TT coyote results
stretch
lufkin,tx
car is 2013 auto
built 11-1 shortblock
precision converter
fore return style fuel system (beefcake)
id1000 injectors
bmr k-member (beefcake)
on3 tt kit with there 67mm turbos and x-pipe
roush axle back
stock gears
k-springs
Triangle Speed Shop (TSS) tuned
first off, car is far from being done with tune. but results so far.
825rwhp 16psi highest dyno #
took it to the track yesterday to do a few real world logs.
horrible weather 96 degrees 90% humidity. car was not ready to make full passes but made 3 logging passes.
best et was a 10.02 @ 143 with a 1.89 sixty ft.
we learned I need a looser converter for sure.
for 1st outing to the track I am pleased being such horrid weather conditions and car is far from being track ready.
I have to leave for work for 2 weeks so I will update on this thread as I make progress.
BMR Tech
Traction Vendor
Tampa, FL
Wow, like psf said, that is pretty awesome considering the sixty-foot.....and even more impressive considering the weather you must be racing in over there, and it being shake-downs.
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
Built shortblk. , specifics please
You're good to go!!!!:highfive:
DO IT!!!!!!!!!
Larry, anyway we can get a pic of the underside of the car from the front to see pipe -to -ground clearance? I always thought the ON3 kits hung low.
stretch
lufkin,tx
DO IT!!!!!!!!!
this kit is all up top? the lowest part of it is the x-pipe.
the only pics I have of underside.
pass side by a/c
down pipe meets x-pipe by starter(no clamp is not touching frame rail)
D98GT
STREETCAR
Liberty TX
Congrats on getting it done. Cut me a deal I can't refuse on the converter when you yank it
stretch
lufkin,tx
it is built for a Paxton for sure. I can get it restalled for free, but I leave out for work mon for 2 weeks then it would take my 2weeks off waiting to get it back. so I will probably just order another one that way it will be here when I get home from work.
CPRsm
You might be better off sending that one back and describe what it's doing and he can make changes. A new one will just be an educated guess. Just a thought. Nice job dude. They look to be close to the map at 16psi.
