You can still run hot rods or for a blower specific cam the comp 127550 have some lope to them. They require springs and phaser limiters but you should change the springs for boost anyway.
I don't think it is a good idea either, but I have seen it a lot.AND WHY THE F$&@ is there no cam bearings!?!?! That's just sounds/looks stupid to me. Bad idea!
just an fyi
make sure your engine builder checks rod side clearance. I've used several Kellogg cranks over the past few years and rod journals tend to run on the narrow side and reduce rod side clearance to less than desirable tolerances for any type of performance application
Were there more problems with the stroker? Nice catch btw.. did not even think of it. Just could not see past the prudy box
anyone got a clutch alignment tool i can have/borrow/buy/trade? thanks
willing to trade for some blacked out headlight covers...
ok thanksYou can pick these up for $7 or so...
Damn I want a loopy cam like my charger in the mustang... But can't with boost
Right?
I run the Hot Rods w/ my DOB kit, and with stock internals and long tubes made 464 to the tire, repeatedly, on an 89 degree day... Might not be the 'ideal' combination, but I would not trade the hot rod lope for another 5-10hp(?) the 'right' cams would make...
