psfracer
billy badass
Look at that mph..........sandbagger.
So does this mean you can put on the 15s now?
Quote of the decade: If you're tired of starting over, STOP giving up.Can't really imagine not having a track nearby. I ve moved five time and have always had at least one track within 45 minutes. Current 25 from the closest, guess I've always been lucky that way.
my first trip down the 1/4 mile
1.750 60'
5.261 330'
8.175 660'
10.690 1000'
12.814 1/4
106.36 mph
'05 mustang GT
stock n/a 4.6L
K&N CAI
frpp shorties/GTA mufflers
steeda UDP
stock trans/shifter
frpp 4.10 gears
eaton truetrac
metco UCA/LCA's
bmr relocation brackets
cobra jet springs (m-5300-q)
strange single adjustable struts/shocks (set to +6 clicks at all four corners)
17" M/T ET street bias ply tires on OEM 10-spoke wheels
OEM pirelli fronts
Fairly new, tires are fine. My best on the 20 was with good track prep. This was at a track with no prep.You actually had a better 60' time with the 20s best pass. How old are the M/Ts you are using?
What was the DA? That MPH is low. Should be at least 113. '60 looks good. Looks like tune is hurting you.
DA was over 900'. A friend of mine was racing the same night with me and her mph was a few mph below her normal, as well. An acquaintance with a '12 Boss 302 was running low traps, too, at just 111. We only got in a few passes before being rained out, so weather was far from ideal.
I will be buying different tunes to compare, but the Bama tune does work very well on the street for drivability.
Yeah you should definitely run better than that. I'm close to your numbers on my tune with street tires and no converter, and I trapped higher. My runs were in roughly 1400 DA. Track prep must have been pretty bad.
