Status
Not open for further replies.
Five Oh Brian
Mustang Guru
New PB yesterday. Car kept getting quicker as the day went along. Was plagged with wheel hop o the 1-2 shift all day. probably a tenth or half a tenth still left in it in it's current configuration. 2220 Is my racing number!
Mods: TCI streetfighter torque converter, 4.10 gears, Bama tune, ORP, custimized stock air box with drop in air filter, EVAP canister delete.
Good year Street tires!!!
5r55s trans
4.6L 3V
Nice! You can update your signature now that you're in the 12's!
Mystickeith50
South Jersey
Full bolt on 2012 5.0 best pass so far. N/A
Looks like that trans is working!!! How.much do u think ur car weights.
Mike Rousch
Richmond,VA
DA was over 900'. A friend of mine was racing the same night with me and her mph was a few mph below her normal, as well. An acquaintance with a '12 Boss 302 was running low traps, too, at just 111. We only got in a few passes before being rained out, so weather was far from ideal.
I will be buying different tunes to compare, but the Bama tune does work very well on the street for drivability.
Very good! The MPH is a little low though, Just to compare in 1744da i went 11.91@114 with the same converter, 275/40/17's and a off road X, and a tune, Otherwise stock down to the stock air filter. (same combo in 244da went 11.63@117)
Get some work done on that tune and some better air and you will be in the 11's no problem!!
Bcalimer
1 7/8 stainless works long tubes 3 inch off road x pipe gt500 mufflers steeda cold air intake aluminum driveshaft and suspension.
Bcalimer
Just the common stuff. Bmr lowering springs double adjustable upper control arm and double adjustable lower control arms bmr lower control arm relocation brackets tubular k member and control arms stock Brembo shocks.
onebadgsx
Houston, TX
new car
2013 auto
5.0
6r80
paxton 2200
9 psi
3.15
m/t et drag
sharkbaits
First Hit on the New Combo
8.59@159
This was done on 275 Drag Radials
Turbo + Power Glide = Fast
jaja6009
Atlantic City, NJ
281 3V Stock heads, stock cams.
FRPP Throttlebody
Kooks Longtubes with cats.
Saleen Series VI 2.3L Super Shaker with 3.4 Pulley 9-11 lbs of boost.
3650 tranny with Short Throw
355 axle ratio
Mickey Thompson Bias ply ET Streets 26 x 11.5 17" rim.
12.004 @ 117.15
To not get my 11 sec slip by .004 is just plain teasing me.
Status
