Installing a paxton novi 2200.
Kenaizer
Denver
Just checking to make sure I understand this. The torque booster from beefcake. The point is to pulley down to say 3.33 and set the spring at say 9psi or around what the 3.8 was giving you. This keeps peak power close to the same but ramps the boost on faster for improved midrange rpm power? Which requires a retune. Who went from a basic kit then added thus..was it worth the coin. Sounds like a no brainer to me?!
Yeah that's it.
beefcake
Forced Induction Specialist
Official Vendor
Bethel, Ohio
here is a graph of the torque booster setup
we picked up .37 in the 1/4 and 5 mph
D
Deleted member 162826
Guest
Oh damn you!!! Haha. I want it. Is that with the stock pulley or did you go down and add the 9# spring?
After the kit is installed how hard is it to put this on? Pull the front bumper and swap the elbow.
07TGGT
@user
Mansfield, TX
I haven't done it but it's a pulley swap and swaping the elbow out. I doubt you have to remove the fascia, it should only be the panel under.
minivanracer
Ocean Springs, Ms
What size pulley can i go down to on the paxton kit without having to dick with the idler pulley on the paxton.
Right now im on the 3.6 pulley one step down. Can i go any lower with just a simple pulley swap and still use my belt.
beefcake
Official Vendor
Bethel, Ohio
no more than a 3.6 on a stock block, unless your bleeding off some boost.
minivanracer
Ocean Springs, Ms
What is all involved in swapping to a 3.33 pulley, I am running an aluminator motor.
Do i have to disassemble the blower to swap belts out.?
Anyone out there got some tips to swap over to a 3.33 Pulley.
DSargent09
Get iT!
You have to move the idler pulley which requires you remove the head unit. Also need a smaller belt.
minivanracer
Ocean Springs, Ms
Ok, which direction do i move the idler pulley,. Do i move it in towards the water pump or away from the water pump towars the fender. Also how many holes do i move it over?
onebadgsx
Houston, TX
Fourth hole from left(towards the water pump) and 100" belt should work. Also have the pull head unit and loosen all bolts on bracket assembly to move adustable pulley. Remove top idler and top spacer.
BV600
TEXAS
Can someone let me know what part numbers go with the coolant tank(ie the hose extension parts)
I'm piecing a procharger kit together but will be using JPCs coolant tank. Just trying to figure out what coolant extensions I will need.
DSargent09
Get iT!
I think this was it.
4fq114-010
It came with coolant tank and all hose and PVC modification parts. It's like 220 from paxton, but a vender can get it cheaper.
bhowardb
YellowBlaze
New build
Last may the rings in #7 and 8 didnt want to play anymore, so I yanked the motor and did a build. While it was out I did tubular kmember and a arms and a few other things. Waiting on my fore innovations triple pump system and it will be ready to tune.
