Wild White Pony
oddly enuff , I cant find the specs on the livernois springs
Livernois springs
- [FONT=Verdana, serif]Specifications:[/FONT][FONT=Verdana, serif]
[/FONT][FONT=Verdana, serif]Install Height:[/FONT][FONT=Verdana, serif] 1.670
[/FONT][FONT=Verdana, serif]Max. Valve Spring Lift:[/FONT][FONT=Verdana, serif] .550
[/FONT][FONT=Verdana, serif]Spring Pressure Closed:[/FONT][FONT=Verdana, serif] 100lbs
[/FONT][FONT=Verdana, serif]Spring Pressure Open:[/FONT][FONT=Verdana, serif] [email protected]
[/FONT][FONT=Verdana, serif]Coil Bind:[/FONT][FONT=Verdana, serif] 1.070
[/FONT][FONT=Verdana, serif]Retainer Material:[/FONT][FONT=Verdana, serif] Steel[/FONT]- [FONT=Verdana, serif]No machining necessary[/FONT]
- [FONT=Verdana, serif]Designed to work with all factory hardware[/FONT]
- [FONT=Verdana, serif]Give added spring pressure needed for any aftermarket camshafts[/FONT]
- [FONT=Verdana, serif]Eliminate valve float to reduce the risk of any engine damage in high lift or RPM applications[/FONT]
