2011/5.0
Iowa
Bmr lowering springs today
swedensky
what's the drop on these? I have the ProKit right now and I want lower but not sure what to get...there's a set of kw3 coil overs in CA for $1400 I was thinking about that but not that much $ on hand...
Wicked GT
OCD with ADD...
Omaha, NE
Sounds pretty good, there is a little vibration when I crank it way up but anything below 50% volume sounds pretty damn good. Would I go through it again versus buying a box... probably not but didn't want to lose trunk space and like things hidden. I should mention with the way I have the gain set and running the amps directly from the stereo it is LOUD at 50%... I actually can't listen to it past 60-65% without my ears ringing like I was at a concert for the next few hours.
loots06
Monterey CA
I'm not sure yet. I'm emailing Brembo and hopefully they can help. If not, I may see if they will my car anyway. I'm also not 100% sure on WTF they go on. The part numbers on the pads pop up on cadillac and camaro forums...
The brakes I picked up say FOMOCO on the back with part number above that. Hopefully you get this resolved and find the correct brakes.
AnotherS197GT
Serial Valve Dropper
USA
I'm 99.9% sure they're for a GM car. I'd love to trade them off for a Mustang set, but they'll probably just get sold. Pretty disappointing, but oh well. I got em for free so at least I'm not out any cash.
Wicked GT
OCD with ADD...
Omaha, NE
Went with a 10"... was originally going to do dual 8" subs but didn't want to rebuild the entire rear deck. Went with the 10" as it easily fit between the speakers.
What size sub?
Just got my hands on a 12" Kicker cvt
Sent from a Galaxy SIII
FAR, FAR AWAY
Scott_0
OxFORD, Pa
pretty damn cool setup man, kudos to you for being different
sent from my S4 using Tapatalk
GT500KR
Quad Cities, IA
finally got around to tearing apart the wilwood disc brake kit i made and sand blasted and powder coated the calipers
GT500KR
Quad Cities, IA
Those turned out nice.
They look really good. :thumb:
You do excellent work.
Terry
thanks guys it was WAY cheaper than a kit you get from somewhere else. i have my own CNC so it makes it handy. these brakes saved me at least twice now...
wanna go to a bigger caliper to use more of the rotor. but these work really great as is and these calipers run me about 100 each where 6 pistons will be 350-450 each. we will see might sell these and go with the new 15" gt500 setup...
