Installing a paxton novi 2200.
D98GT
STREETCAR
Liberty TX
I understand
This beast is supposed to be ten psi right now
I have other pullies that came with this kit too
Once I get oil pump gears and the fuel system I am going to swap over to corn and have TSS set it on kill
Daniel told me that they are getting an e85 station near the shop so they'll start being able to play with it some more
gremlinsteve
I have it all around me where I'm at
But with my current level I'm just not trusting the
Stock pump to keep up in volume
I'll go with a dual or triple 465 hat
D98GT
STREETCAR
Liberty TX
I have seen some great numbers from the E85 guys with the novi setup, I am a bit jealous but it's just not here for me to run.
It gets expensive when you start adding in the cost for the fuel setup
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
If you are getting an OEM water pump I recommend Steve@Tasca, he is a vendor on here and has the best pricing I have found.
DSargent09
Get iT!
I stuck stock pulley on it and have no issues yet. The difference was very slight, and they have the same number of ribs.
DSargent09
Get iT!
EDIT-
Found small issue causing some of the problems. Seems like the tune just isnt right. Ill give them one more revision then I'm switching tuners.
Bullett
Pwnisher
Mission, TX
So I scooped up a beefcake torque booster. Looking forward to see what it does! Best et has been 10.9@130 on the blower, 3.6 pulley, and a x pipe on 93 pump and 18" drag radials.
beefcake
Forced Induction Specialist
Official Vendor
Bethel, Ohio
what was your peak boost before? 11?
you may need a spring change to make it comparable, if you were already running a 3.6
Bullett
Pwnisher
Mission, TX
In the cold I was seeing 11-12 or so. In the heat or normal local weather 9. What spring should I drop in there? Should I ask ken b also what he recommends?
