Installing a paxton novi 2200.
DSargent09
Get iT!
Oh shit. Hope that's not why the car ran piss poor around the block the one time I tested it.
moostang09
Resident YouTube Guy
Mansfield, Tx
Using a kit from beefcake and id1000 injectors mine just made 672/574 on a mustang dyno using pump gas and stock exhaust manifolds jegs cat deletes and stock cat back
Can't go wrong
I used triangle speed shop
I've heard a lot of good things about Triangle! Out in Orange, Texas right?? I may go there when I get my kit one of these days.
Are you keeping the power that high it will you roll around on a more conservative tune?
Eventually I would like to be on a really safe tune and make around 600 to the wheels.
DSargent09
Get iT!
right is what comes on 2014s left is pulley that comes with kit.
Going off memory my car is 10/13 build date.
DSargent09
Get iT!
Nope, wasn't very much of a size difference so I left stock one on. I tried to text beef, but didn't get a re.
You're right though I'll give them a call tomorrow.
Greg Hazlett
Stepping on the Pink Bus
Chesapeake, VA
Understand; when I was about to put the kit on my car I swapped over the WP pulley and the stock belt appeared to have one less or one more rib than the Paxton belt which is why the WP pulley needed to be swapped.
DSargent09
Get iT!
hmmm. I will definitely call paxton tomorrow, and if I dont get a re from them I will double check the ribs on the pulleys this weekend. Car is still sitting on ramps in the drive way. I have yet to cut and reinstall the lower splash shield just in case something needs attention.
gremlinsteve
That's the idea. The set to kill tune and a lighter tune. I plan on future mods and will have a beast mode tune also.
Just for show as i do not get to get to the tracks much
racksteris
Can't go wrong
My Vortech GT/CS made 680/577..I'm running a 600 HP tune until motor is built.
beefcake
Forced Induction Specialist
Bethel, Ohio
yep, give vortech / paxton a shout, they will get you the correct pulley
lemme know if you need anything
Witt
Pittsburgh, PA
I have a 2014 with a 11/19/13 build date and have a 3 bolt water pump pulley as well. This might put the kibosh on my paxton with 8 rib plan. Any idea if they make a compatible 8 rib pulley?
onebadgsx
Houston, TX
Call them, also check with jpc.
gremlinsteve
Depends. My 3.6 pulley actually made 13.5 psi. I'm still over 10 psi with the stock 3.8 pulley.
I understand
This beast is supposed to be ten psi right now
I have other pullies that came with this kit too
Once I get oil pump gears and the fuel system I am going to swap over to corn and have TSS set it on kill
