JimC
I guess this is really two days worth - picked up the car from the shop with the new cowl hood from RevelareDesign.com on it and new paint:
Then I drove it to the office the next day, because it was supposed to be "warm" (in the upper 20's and mid 30's) and no snow or bad weather. I needed to burn off some gas from the tank so it is down near 1/4 before I take the car to Detroit Autorama set up on March 5:
Typical Michigan weather and the forecast being off just a little.
lindertw
NoVA
I checked the view with my gopro mouned on the panhard bar. Hope to see what the suspension is doing at the track (and I plan to put a stripe on the inside sidewall of the tire to watch for tire spin).
Marc s
NASA AIX
Auburn, WA
Whats the purpose of the cut back ground strap?
Better combustion efficiency. Kind of like indexing sparks plugs. Both methods add a fraction more hp. Not worth it for a street car. However, in class racing, every hp counts.
Marc s
NASA AIX
Auburn, WA
My ABS delete manifold arrived today from PRB Machining. The quality of work is amazing and is 12lbs lighter than the OEM unit.
blk12gt
San Antonio
Very nice, it will look very clean being able to use the OE lines. If you dont mind me asking, how much was it?
Sent from my phone, spelling mistakes brought to you courtesy of tapatalk.
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
Dropped my car off at Mid Atlantic Performance for a Circle D removal for a reflash and NA tune in preps for the May track rental.
blk12gt
San Antonio
Very nice, any reason you went that route instead of fabbing new lines w a distribution block and prop valve? Good work is never cheap.
Marc s
NASA AIX
Auburn, WA
It was just easier this way.
weather man
Persistence Is A Bitch
MN
Stay safe LITO. Things are getting interesting in your country sir.
