07 procharger
Addicted to modding
Red Deer Alberta
Sent from my iPhone using Tapatalk while Moonwalking
like your style...I don't know about you, but that install was a PAIN! I don't know if I would do it again.
LAStang1234
----------DSL----------
Little Rock
Wasn't too bad at all. I don't know why they think batteries are 2ft tall though! Have to bend the cable at ridiculous angle for it to connect.
GreenTerror
Rogers, AR
Installed my koni yellows, steeda comp springs, strano sway bars and steeda camber plates. It took us about 4 hours total with the mandatory beer brakes and taking our time. Front before to fender 28 1/4" after 27 3/4", rear before 29 3/4" after 27 3/4". I am happy with the stance!
Pictures for your enjoyment :beer:
GoneFord
Yorktown VA
I didn't care for the tight turns you have to coerce the cables into to get them to connect either. But I'm very glad I went with welding cable and not standard battery cable.
JoshK
Modder AKA Fuel
Nebraska
Wired up the Reverse Lockout on my TR6060. I don't care what people say about not needing to do it, it is too easy to not do. Also went out and made another log for Manuel.
Onelildude
Georgia
Replaced my front and rear rotors and pads. Took about 2 hrs...I'll get pix later when the rain goes away
K_Brogoitti
Columbia Basin
Trimmed a little off my axle backs cause I didn't enjoy the way they looked sticking so far out of my bumper. Wasted a Lightning stoplight to stoplight... Twice! Shoulda seen the look on that guys face when I dropped the clutch at 6 grand doing 30. My long tubes sounds SICK!
Sent from my XT1080 using Tapatalk
stang8psi
Slower,Lower Delaware
Aluminum ds, lower control arms..new wheels.. funny the rear end moved to the right (pass side) some after the control arms.. wonder why.. now I have to adjust the pan hard bar.. haven't had to adjust it.. haven't had to un 3 years Lol
LAStang1234
Little Rock
Looks good! I installed the same Taylor box over two years ago and just got around to cutting the hold down rods to proper length a week ago.
Scott, where did you ground the battery at?
Would this be a good spot to use as a ground in the trunk?
doogie
SE WI
Finally got is out of the garage, but the battery is shot... So I need to grab a new one before the first real drive of the season... Which can't be soon enough!
AnotherS197GT
Serial Valve Dropper
USA
Swapped my summer wheels back on, greased my brake slide pins, and discovered a huge pinion seal leak. Ordering 4.10s and a T-Lok rebuild this week. What has me worried though is idk if its because its got 110k, or because its been lowered on a stock UCA for a year.
