W3bb3r04 build thread
W3bb3r04
Slow 3v Member
Clinton, TN
Yes. We measured over 500 cams, 20 degrees retarded and still had a huge gap with stock stroke. Even on a stroker, they work.
Enviado desde mi XT1053 mediante Tapatalk
Okay thanks! I guess I know which direction Im going!
I know you time sensitive, but swaintech does awesome piston coating (top & sides).
I think the skirt coating should be plenty plus this is somewhat price sensative as well and dont have an extra $400 to spend on the pistons. They do have some good looking stuff though. Thank you!
Weou09
Bham, Alabama
If a valve relief is really not needed then I would go with the Mahles for a 2v/4v. They are identical to the 3v specific, with no relief. They are by far the cheapest and come coated.
W3bb3r04
Slow 3v Member
Clinton, TN
They dont make them in .030 over though, only standard and .020 over. I ended up buying the Manleys.
jodadejss06gt
TEAM DELETE SHIT
Severn MD
can you reuse head gaskets or do you have to get new ones. Reason I'm asking is because I have brand new TTY head bolts that I won't use. Didn't know if you needed them or were buying a new head changing kit or had ARP hardware there.
W3bb3r04
Slow 3v Member
Clinton, TN
You probably can but I already tossed my old ones and have a new head changing kit in route. Thank you though!
W3bb3r04
Slow 3v Member
Clinton, TN
I just got a chubby
dysan
Dis-Member
Williamstown, N.J.
Hey, those look familiar! I have the Manley flat tops in my current engine...granted they are only .020 over. What I like about the Manley ones is their spec is for tighter clearance so there is less chance of cold startup piston slap noise. I have zero noise on mine when I start it.
JeremyH
3V Fuel Guru
Virginia Beach
Should be fine with corn for your build Josh. Just seen too many cases over the years on both 2v's and 3v's of burning holes or ringlands out with 4032 pistons and a turbo setup, even on mild boost/power setups.
dysan
Dis-Member
Williamstown, N.J.
I like that setup as well..working good for me. My car weighs 3940 with me in it and runs 11.0's with the lowest boost I can make on my e-force...6-8psi(due to a 10% od balancer) and that is with my trans being hurt.
