GallopingFord
I'm Cam - Mr. Indecisive
Northern Virginia
Took it to cars and coffee this morning and saw some badass cars including this.
weather man
Persistence Is A Bitch
MN
Just had fun driving it. Got a nice 4th gear pull in with the wife.
o2sys
Fabman, they are still available but just the core. I made my own wiring and hoses.
Just tightened up all of my custom exhaust. I've been getting a little whiff of alcohol at stops and I'm fairly certain it's coming from my exhaust. I need to invest in some better clamps for the cats or weld them on.
Bruce, I've had issues with the band clamps stretching out and not clamping securely as well. Using Permatex muffler and tailpipe sealer helps but the real solution I found was wrapping a couple turns of heat reflecting tape around the pipes to make them fatter so the clamps will squeeze them tight. No more pipes falling out of the fully tightened clamps!
XJCasper
Yelm, Washington
After the negative issue that started my weekend, I decided to spend today, picking up parts. Tomorrow to maybe install BruceH wheels and deal with insurance companies.
Sprayer84
Omaha, Nebraska
Picked up some steeda billet delete plates. Going to put the stock intake/TB back on and sell the C&L to somebody that can take advantage of it.
GreenTerror
Rogers, AR
Had an alignment done after the suspension install. It was pretty close to speck, toe was a little off. Had camber set to -2.
