LCA's and or UCA's do we need them on a DD that has been lowered?
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
All I'm really saying is that if you are going to start replacing control arms, regardless of the reason behind it, the UCA is the one to start because you can do "everything" with that control arm you could do with the LCA's without the negatives of adjustable LCA's.
You cannot change roll steer characteristics without doing LCAs and anti-squat brackets.
Bill220
Cut em. I had Steeda Sports on my '06 and had to cut the bump stops because it was hitting them hard. Then I put UPR/Eibach Pro on my 2011 and REALLY had to cut em! (down to the last big section)
How much did you cut off with the Steeda Sports? I have them and never thought of cutting the stops. Maybe that's why my car rides like shit over even the smallest bumps.
Whiskey11
SCCA Autoscrosser #23 STU
Actually, you can change roll steer by changing the length of the lower control arms but the effect is pretty minimal compared to that of the relocation brackets.
