Oil pressure helppppp
1bad99
First crank on oil pressure was good after idling for 5 min checking for leaks and all went back inside car and saw low oil pressure and gauge was at L/0 turned off switches oil relocation hoses around cranked same thing switched back as before cranked couple times nothing disconnected tue I oil feed and was pumping thru into a bucket for like 5 seconds then put back hose and cranked and bammmm oil pressure was all good over half gauge then a minute idle and low oil pressure any suggestions
1bad99
Ok so I took off front cover and plug was there should I just replace oil pump now that I'm there
Excess RTV sealant scraps getting sucked up in the oil pickup screen at the bottom of the oil pan?
Should I install new one and go with it
A new what? Two people in a row just suggested it's probably crap in your oil pan. If the crap is big enough to plug the oil pickup then it may not come out of the drain plug. Before you go buying new parts, how about figuring out the source of the problem? Is there crap in the oil pan? Answer that question before asking if you should buy a new oil pump.
1bad99
Will do haven't checked but is it possible to drop pan with motor in or I have to lift it a bit
michael.konor
Georgetown/Fort Hood, TX
With the BMR K-Member, I had to drop the steering rack and let hit hang, as well as disconnecting the motor mounts, loosening the transmission mount, and then raising the engine by 1".
michael.konor
You could inspect the pan and pickup with a remote inspection tool. They are under $100 at harbor freight.
I've had debris in the oil pickup screen and it didn't affect the oil pressure. I think it would take quite a bit. Mine was from pulling the front cover about 6 times.
I'm wondering what the clearances are and what oil you are using? Are there any special considerations for oil level and an oil fed turbo? Things like drain back affecting the level?
You could try unbolting the motor mounts from the k member, jacking the motor up, putting something under the mounts to hold the motor up a few inches, and dropping the steering rack. Not in that order but doing those things should give you enough room to get the oil pan out.
1bad99
using motorcraft 5w20..... i was also thinking the same as far as drain back and being that it was the first crank up tensioners, lifters, filter relocation lines etc. were dry, including turbo feed line and time to drain back. Bruce i inboxed you but says you have too many messages lol
thump_rrr
Montreal Qc,
Was the engine pre-lubed with a pump sprayer or anything prior to start-up to lubricate the upper end and pump up the chain tensioners?
1bad99
No it wasn't that was my bad I had never heard of pre lubimg it I've always just primed it without injectors and coils connected
retfr8flyr
The Old One
Providence Forge, VA
What about the plug at the rear of the block? That can also cause no oil pressure. Can you check with your machine shop and see if the plug was replaced?
1bad99
havent checked the rear i checked the front plug and its in there.......... i will also check my chain tensioners see if they leaking
1bad99
Well front and rear freeze plugs were in what is the next step to look for or what totally lost
