D98GT
STREETCAR
Must be nice to be rich
You guys running no air filter at the track... are you just removing the filter or the whole inlet tube?
I used to remove the complete tube. I believe though its doesnt help as you suck in hot radiator air.
Good point. So you just remove the filter off the end of the tube now? Or run with the filter on?
I also feel his numbers might be inflated..... Could you post the sheet? What dyno...
680 on 7-8# is a bit unrealistic unless you have other supporting mods, or not stock motor.... even then idk..... maybe I'm an idiot.
