Installing a paxton novi 2200.
onebadgsx
Houston, TX
Actually had a change in plan. Going with a Bell Intercooler custom built vertical flow. Ordering today. I update with pics. Core will be 6" thick by 12" high and 24.4" wide. Flows 2500 cfm, with very little pressure drop.
Then a little dry n2o on top, things should really stay cool.
fiveoh
You guys running no air filter at the track... are you just removing the filter or the whole inlet tube?
fiveoh
I used to remove the complete tube. I believe though its doesnt help as you suck in hot radiator air.
Good point. So you just remove the filter off the end of the tube now? Or run with the filter on?
D98GT
STREETCAR
Liberty TX
Is there really a reason to be so short/secretive in this information thread? Acting like a damn grudge racer haha
DSargent09
Get iT!
I also feel his numbers might be inflated..... Could you post the sheet? What dyno...
680 on 7-8# is a bit unrealistic unless you have other supporting mods, or not stock motor.... even then idk..... maybe I'm an idiot.
fiveoh
That's about right on E85 and a slightly happy dyno.
