So you only gained 3HP from going with a Boss IM?
No, he only gained 3hp on the same dyno on a different day with different weather.
Everyone keeps missing that the worry here is that it's 3hp from STOCK. That first pull was STOCK TUNE and now it's a few bolt-ons and a tune. And not just one tune, I tried 3 different tunes. This pull gave the best results.
As far as data logs, I'll get it up ASAP. I know that on the road as well as the dyno the actual spark was what is commanded. Starts at about 20 degrees around 3k RPM and tops out at 27 degrees at 6k RPM and up.
RPM redline is 7800 but we only pulled to about 7500 RPM on the dyno.
AFR at wide open throttle is 11.9. Very consistantly as well. That's using the wideband in car. Dyno wideband at tail-pipe was about 12.1.
Load readings at 3-4k RPM was 1.01 and held until about 4800RPM where it drops slightly. By 7600 RPM the load reading is about .92.
MAF airflow is about 46 G/M by 7500 RPM.
Everything there is adding up to what I would have expected to be about 420 RWHP.
I do not have Boss valve springs or the billet oil pump. I do plan to get both as soon as I go FI but not until after I figure all this out first.
The power curve looks fine, just low according to the dyno sheet.
Again, I am not "racing the dyno". I am using it as the tool it is. I am comparing where I starter to where I am now. I do know it's on different days but that is why we have correction factors. According to a couple, the correction factors are useless as well? Even on the same dyno? I don't know, I'm just making sure my car isn't having a serious issue. If this is what it is and everything checks out, then so be it. It just threw a red flag for me.
Thanks for all the input.
