Fuel's Winter Project: Build It Before It Blows
Top of fourth on a long pull, wasn't lean,no detonation....just a lot of heat....pop....enough smoke to let me know it was fucked.
Mahle, livernois 4032 Pistons.
FWIW Livernois changed the standard Mahle ring grooves to their specs. IIRC it was for more piston top before the first ring.
05stroker
Never enough power guy!
Bullard Tx.
I think I know the issue, you all use the same tuner, lol. :crazy:
Haha, I wish. Its not that easy.
Maybe turn the power down to 700 or so? Never happen, lol.
What? That was two years ago!
Didn't you get the memo for 2014, 1000rwhp is the min. :thumb2:
We don't drive our cars to drive the car, we drive them to scare the shirt out of ourselves!
JoshK
Modder AKA Fuel
Nebraska
So is it a consensus that I should tear it all the way down to inspect and at least re-ring?
JoshK
Modder AKA Fuel
Nebraska
Not sure I feel comfortable just throwing some new followers in there and trying it again. I have at least 4 months of snow coming so I have time
JoshK
Modder AKA Fuel
Nebraska
I thought you had stock heads? Go ahead and through some more info in here.
Dark_horse
KC MO
His name is Eduardo Melgar and owns Eds Speed Shop... heads and cams supported almost 1300whp and 980ftlbs of tq on his 298ci motor I believe... they do extensive chamber work, cnc ported, unshroud the valves, +1 bigger stainless intake valves, stock exhaust valves, manyley springs and retainers.... I have pictures in build thread... they flowed 280/210 if I remember correctly...
Stock head flow:
Intake
Lift---- CFM
.100-----77.1
.200----147.0
.300----199.6
.400----216.0
.500----223.2
.600----224.8
Exhaust
Lift------CFM
.100-----52.7
.200-----97.8
.300----120.2
.400----138.1
.500----148.2
.600----153.7
JoshK
Modder AKA Fuel
Nebraska
My thinking right now is if the block is okay maybe get a different set of .030 pistons, but in a 2618 alloy this time that require a little more ptb clearance. Rehone and go back together with upgraded wrist pins, stronger pistons and a forged crank. Think that is doable?
