swflastang05
Back for More
FYI the Ford spec is no more than .001" over 4" iirc. You also want that for the block deck.
No cracks on the cylinder walls I assume?
Well, using a level I have and the smallest/thinnest feeler gauge I have which is .0015 I wasn't able to get under the level anywhere, I criss-crossed the head every way I could and the feeler gauge wouldn't slip under neath. I'm going to borrow an actual "straight edge" from a buddy hopefully tomorrow to make 100% sure but so far it seems to be straight. Haven't checked the block yet, will check that with the "real" straight edge. Thanks Bruce.
I can easily reassemble everything but it sure would be nice to have some peace of mind finding something definitive that caused the failure and knowing what I can do different this time to ensure I don't have a repeat.
