UltraKla$$ic
PERENNIAL WAXXER
Sai and Jim both have SWEEEEEEEET ON3 Setups.
My bad. I thought you had one.
Stretch(Larry) has one and he has some good times with his. I'm pretty sure it's TSS tuned like slagburns.
I don't have a on3 kit, I built my own. But I did install Sai on3 kit and it went great, fit good out of the box no modifications beside the 3.5in intercooler piping I made for the Maf, so he wouldn't have to upgrade. the kit has been 9.9 on the stock motor so far.
You installed a on3 kit?
If you don't mind, tell me how much you hated your life during the install, because that's really the only reason I'm undecided between that and a vortech at this point, worrying about how hard the turbo install will be compared to an easy centri that is.![]()
Whoa.. not TSS tuned here. I tuned it with hptuners and a lot of help from Sai.
TSS seems to do a lot of them is why I mentioned the shop.
Ooops...........guess I need to shat up then. lol
I'd put one on my car if I had the money. Only thing that would concern me would be ground clearance. My car sits really low.
I put one on my car. Lots of work but it all fit like it should. Go For it!! Pretty decent kit right out of the box. Get the on3 x-pipe and you are ready for some big numbers. I made 875 on 13 psi out of the box.
