Scott
Shorten, Build and Install an 8.8 Bullet Proof (Hopefully) Differential
This winters major mod is a shortened 8.8 differential build. My objective is to narrow the housing one inch per side to be able to “air out” the Air Lift suspension with P325/50R15’s mounted on 10” Race Stars wheels. If this doesn’t work I will move down to P295/55R15’s.
Parts list of what I already have so far:
• Differential Housing – DR3Z-4010-A
• Ford OEM Differential Bushing – B33Z-5A638-B
• BMR Suspensions Dual Durometer Differential Bushing Kit – EN001
• Moser Engineering Main Cap Stud Kit – 7116
• Ratech 8.8” Solid Pinion Bearing Spacer and Shim Pack - 4105
• FRPP Axle Girdle Cover Kit – M-4033-G2
• FRPP Ring and Pinion Installation Kit – M-4210-B1
• ARP 8.8 Ring Gear Mounting Bolts – 250-3003
• Lube locker Gasket – LLR-F880
• BMR Suspensions Control Arm Relocation Brackets – CAB005
• BMR Suspensions Upper Control Arm Mount – UCM001
• Steeda Adjustable Upper Control Arm – 555-4105
Parts list of what I need to purchase:
• Strange Engineering 2005-2010 Mustang 8.8 35 Spline Axles, C-Clip Kit, ½-20 3” Studs and Light Weight Spool – P3509F05S
• FRPP 4.10 8.8” Ring Gear and Pinion Set – M-4209-88410
• Pinion Flange – TBD
• AMSOIL and Royal Purple Gear Lube – 75W-90
Mods will include:
• Shorten Differential Housing 1” per Side
• Weld the Axle Tubes
• Paint the Axle Housing and other components
• Install the Gear Set
• And of Course Re&Re the Housing
Since I am using a new housing I needed to buy an OEM Differential Bushing. The new bushing casing was prepared for installation in the housing by drilling out the OEM rubber bushing insert.
OEM Bushing BR3Z-5A638-B
I used a drill, 1-3/8” and 1-1/2” hole saws to remove the bushing and then cleaned up the remaining rubber remnants with a small wire wheel. The BMR Dual Durometer Differential Bushing (# EN001) will be installed after the bushing casing is installed in the differential.
Bushing prepared for installation.
Ratech 8.8” Solid Pinion Bearing Spacer and Shim Pack – 4105
FRPP Axle Girdle Cover Kit – M-4033-G2 (to come off my current differential)
Ford Axle Vent Hose Assembly – AR3Z-4A058-B (to come off my current differential)
BMR Suspensions Lower Control Arm Relocation Brackets – CAB005
Steeda Adjustable Upper Control Arm – 555-4105 (to come off my current differential)
Mods will include:
