BOOST!!!
Domo34
Hampton roads, VA
How's it going guys, I just bought me a 08 GTCS it has 101xxx miles and I was wondering would it be safe to push 7-10 lbs of boost usin a 70mm turbo on stock internals
Department Of Boost
Alpha Geek
Boost is irrelivent. HP is what matters. You can run 450ish HP at the wheels. If that takes 1 or 15lb it doesn't matter.
weather man
Persistence Is A Bitch
MN
Attack of the Saturday morning NOOBS!
Department Of Boost
Alpha Geek
Torque eats rods, if you have 430hp and 500ft-lbs say bye to your toothbrush rods :roflmao:
Yes and no. RPM's eat rods too. The loads on the rods go way up as RPM increases. It's not linear.
But you are correct, I should have been clearer. 450/450 would be the best way to put it.:thumb:
thump_rrr
Montreal Qc,
Bullshit.
I've been boosted since 2006 for over 80,000 miles on stock internals.
I've been at 498/499 since 2008 with no issues.
I've been at 543/499 since 2010 with no issues.
The car is not treated with kid gloves either.
Proper tuning is the key.
Detonation is your enemy.
Bullshit.
You got lucky. The rods are pretzel sticks.
BadPiggy
Hooligan Ahole
Knoxville, TN
I say get the S&H Twin kit and turn that sumbytch up.
fdjizm
Drag Queen
Bullshit.
How much of those 80,000 miles are racing?
Congrats on a good tune, but I wouldn't push it at those levels.
I'd say you got lucky and it's not the norm, why not try 600, 700, 800 then?
thump_rrr
Montreal Qc,
Over 2,800 1/4 mile runs.
Some lapping thrown in too.
It's been pushed hard enough to shatter 1 pinion, 2 Detroit Truetracs', 1 Wavetrac, and a TR3650 input shaft.
There is now a Currie 9" with 35 spline axles at the rear.
In 2005 when JDM tuned their red S197 with a Saleen blower the thought was that 450rwhp was the limit and slowly people have pushed the envelope.
JDM and some other tuners are able to consistently get to these power levels without issue.
That is not to say that I wasn't warned that I should plan on building a bottom end.
There is a JDM shortblock sitting in my garage waiting on heads and cams.
The car will once again be driven 400 miles to JDM for tuning once I build and install the motor.
The reason I don't want to go further on the current engine is that it will serve as a backup just in case something goes south with my build.
I have seen too many builds go south over the years and summer up here is too short to go without my car for long periods.
Doug M
Fast Cars & Freedom
AL. Baby
Thumprrr. That's awesome! I want to boost mine at 60k and just drive the crap out of it.
Riptide
Will work for Mustang.
Montucky
Marc had pretty good luck with his stock internals IIRC.
Are the rods in the 3v really that much thinner than the coyote? Seems like I've seen photos of the coyote rods and they didn't look much better.
fdjizm
Drag Queen
I love that you beat on it and I am glad it has held up, I am still going to say your situation is an exception not the rule.
I've actually had a buddy (he's on here) blow his JDM tuned engine at 430rwhp. (not to say they aren't good tuners just that every engine is different).
So I am going to stick with you've been VERY lucky and it's a good thing.
I've seen/read/heard of enough engines being blown even by great tuners to know that not everyone gets away with everything.
