You'll be fine as far as clearances to the strut on the inside and the sheetmetal on the outside are concerned. Relative to a +45 GT500 wheel, your +48 steals 3mm away from about 10mm clearance, but the 1/2" narrower width buys you back about half of 12mm, so you'll be 3mm better off (~13mm wheel to strut clearance, which *should* be enough to fit a 275/xx tire). On the outside, you'll have 3 + 6 mm more clearance than with a GT500 wheel.
For rotor clearance there are two other clearances involved.
One is radial clearance to the barrel of the wheel. The *safe* assumption is for the nominal wheel size to be 4" greater than the nominal rotor size, though tighter fitments are possible depending on the actual rotor diameter and caliper dimensions and the actual thickness and contour of the wheel's barrel itself. My guess is that a steel wheel can be a little thinner and flatter for greater clearance.
The other is clearance to the back sides of the wheel's spokes. Brembo calipers in particular require more room this way, so the shape of the back sides of the spokes and/or the mounting pad height matter for this one.
