6R80 transbrake you say?
2FST-4U
louisiana
Shit I have been 1.33 60ft on foot brake circle d 2c with my Paxton car. Triangle speed shop tune and my Friend Sheldon has been 1.30 60ft on foot brake. 8.99@151 Sheldons car and 9.06@151 with mine.
Bud
Northern Colorado
Jon's car moves the fuk out! That 1.28 60' was ridiculous! Many thanks to the BG glue gods, and was pretty incredible that the driveline held up to that launch at that weight. Was awesome to see
CPRsm
I am curious, how many trans issues have you heard of from those using your version? I haven't heard of or seen evidence of any using the 2 or 3 relay version. That is a genuine, sincere question.
honestly I only know of two 80's w any problems and they were both running the dual relay. Ea one I think blew a different planetary. Jon and Sean Kelly. Brett is the first to have anything fail other than Chris's stock bushings lol. But even Brett's failure is pretty common now a days I guess. W or without a brake
I have seen timeslips from the same car running 1.32, 1.33, 1.35, 1.36 on the 2 relay setup.
I hadn't seen anyone post anything in that area before. We're still going to keep ours a secret as long as possible. It still has some very distinct advantages to keep under the hat for now.
wbt
That is interesting. Do you recall if they were using the 2 or 3 relay version?
Not a thing wrong with that.
D98GT
STREETCAR
Liberty TX
Wonder what my little Paxton car would do with this?
My numbers today from the dyno made me feel good :)
Justinjor
JUIC3D
Nope just one. The one you saw was being tested and already off the car.
Definitely two in the area but it doesn't matter. I doubt they would spill the beans on the schematic so the leak is from somewhere else. haha
Chris5.0
Sarasota FL
Justin what are you talking about leak? The eBay one is not cave brake it's a Danner design. And no one has leaked this brake. Jims car had it for testing sais car and my car have it. It's leaked when plans are published. And I see no plans.
Justinjor
JUIC3D
Apparently my browser didn't update with all the posts so I just now saw that it wasn't the cavebrake. Funny that someone even put the relays in a box to mimic the cavebrake though. That's comical. The single biggest form of flattery is imitation.
BMR Tech
Traction Vendor
Tampa, FL
Don't you have a car 60' around the 1.2X mark without a transbrake?
I have been assisting VMP with their suspension.
Ironically (wbt, you'll like this) - it did go a 1.28 last Sunday....AFTER putting our lowering springs on it. Our goal was a 1.2X...and bam.
It is a footbraked stock converter car.
BMR Tech
Traction Vendor
Tampa, FL
I will not post those as the owner would much like his privacy kept. It will be up to him if he wishes to divulge.
Those are impressive!
I completely understand the privacy part of it.
Is there any way you can share details on this set-up though? Turbo, I assume? What kinda parts is this car using? Built motor and trans? Is it on a slick or DR?
REDS197
Denver
Footbrake and Stock Converter!
Thats Awesome!
wbt
Local guy I have been helping and he also has lowering springs on his car. ;)
In fact, I will be moving to some myself in the near future. I have had a change of heart on it after seeing the way his car performs.
FATHERFORD
I read this thread and still more confused then ever.
Big HP Twin turbo coyote with Circle D converter and Circle D Trans.... Will the 2 relay version with no tune mods hold or not?
Justinjor
JUIC3D
Inferred movement or stall speed has to be raised in the tune for a converter and also transbrake use. Since it's not likely you'd put a transbrake on a stock converter car, this parameter will already have been raised by whomever tuned the car. Aside from that, no other tuning changes are necessary.
I don't have big power, but mine holds fine on my TT coyote.
FATHERFORD
Ok thanks, My car should be doing over 1200rwhp so I'm just curious if it would hold.
Justinjor
JUIC3D
Many big power cars use the same transbrake and are reporting good results. Specifically Power by the Hour and their big power cars. Ken's stock motor car went 9.3@145 with the 2 relay brake and their built motor cars are even faster.
CPRsm
Total power of the engine doesn't matter unless you're going to try to build 20+psi on the brake. Only needs to hold what you can launch with
