stuck till i can drain fluids
He's just using that as an excuse to play with the 02'
Nice jack for getting the car up to put stands under it, but no way in hell would I get underneath without stands using that jack.
how do i remove crank pulley bolt? IF i use a ratchet it just spins the motor i cant get the dewalt electric impact in there the radiator is in the way. how can i get the pulley to stay put or the motor to stop spinning?
I wedged a bar in the crank to stop it from turning.
How did you do it last time when you removed the 18% OD pulley?Its an Ionnovators west, nothing to wedge into
It sure looks liek it in front of my house
Tbird, Saturn and Explorer arent being used. Literally jsut extra cars we havent gotten rid of, although the saturn is basically junk(i guess it was junk from thefactory too)
Firebird - brother
Expedition - Father
02 Mustang - Mine
Honda - Sister
G37 - Step Mother
Rent a pulley puller kit from your local auto parts store.
Go rent "THE CLAW"
I put mine in forth gear and applied the parking brake, use a long ratchet or breaker bar. My car tried to roll a little bit but came loose no problem.
Zackly...The innovators west pulley doesn't need a puller either. it has bolts built in that you use to jack screw it off.What the hell does a pulley removal tool have to do with getting the crank bolt out?
Pretty much what I was going to suggest as well. Put it in gear, double hand full of park brake, and a breaker bar with a big ass cheater bar.
Im not sure on a standard car but on mine I use a bar through the hole in the block to access the TC bolts on the flexplate . Do you guys have holes on the back of the flywheels ?how do i remove crank pulley bolt? IF i use a ratchet it just spins the motor i cant get the dewalt electric impact in there the radiator is in the way. how can i get the pulley to stay put or the motor to stop spinning?
Yep, get ready to blow a nut........Long ass breaker bar and the car's parking brake on.![]()
I do the same except put it in 5th. The highest gear will give you the best holding power.
