Motor is gone
94tbird
4R70W FTMFW
how do i remove crank pulley bolt? IF i use a ratchet it just spins the motor i cant get the dewalt electric impact in there the radiator is in the way. how can i get the pulley to stay put or the motor to stop spinning?
KIMMER
Admin
Nice jack for getting the car up to put stands under it, but no way in hell would I get underneath without stands using that jack.
94tbird
4R70W FTMFW
if anyone went under the car with that they deserve to have the car fall on them
Dex
I'm Dexolishous
Utah
I wedged a bar in the crank to stop it from turning.
white05gt
Illinois
I put mine in forth gear and applied the parking brake, use a long ratchet or breaker bar. My car tried to roll a little bit but came loose no problem.
ZmanM3
The Evil One
Jackson, NJ
It sure looks liek it in front of my house
Tbird, Saturn and Explorer arent being used. Literally jsut extra cars we havent gotten rid of, although the saturn is basically junk(i guess it was junk from thefactory too)
Firebird - brother
Expedition - Father
02 Mustang - Mine
Honda - Sister
G37 - Step Mother
Still live at home with mommy and daddy?? Haha, had to do it.
I put mine in gear and engaged the parking break.
Hawgman
THE fucking bad guy
Rent a pulley puller kit from your local auto parts store.
Go rent "THE CLAW"
What the hell does a pulley removal tool have to do with getting the crank bolt out?
Pretty much what I was going to suggest as well. Put it in gear, double hand full of park brake, and a breaker bar with a big ass cheater bar.
KIM_05_GT
Zackly...The innovators west pulley doesn't need a puller either. it has bolts built in that you use to jack screw it off.
KIMMER
Admin
Yep, get ready to blow a nut........Long ass breaker bar and the car's parking brake on.:thud:
05stroker
Never enough power guy!
Bullard Tx.
Im not sure on a standard car but on mine I use a bar through the hole in the block to access the TC bolts on the flexplate . Do you guys have holes on the back of the flywheels ?
luv2cheat
Goodland,IN
I do the same except put it in 5th. The highest gear will give you the best holding power.
