2005 mustang gt 99% stock, sputters horribly
YellowRoush
Houston,Tx
I'm not 100% sure if it's the intake per say but it's around there. I think it's the actual intake before the TB. Anyway to go about checking that?
YellowRoush
Houston,Tx
And another thing is it does this very speradically
Drove it the other day and it ran PERFECT for 15 minutes. Then started running like shit and popping and surging again. It's pretty much like the cars bi polar.
Aesthetics28
Me likey, I thought u were gonna say Lotus which I'm also a big fan of. I wouldn't necessarily say though that any car is a waste of time to work on cause its always a way to explore, troubleshoot, and just straight up learn with.
YellowRoush
Houston,Tx
Oh I learned alright. I learned I shoulda cut my losses while I was ahead lol. After getting stomped by a stock c6z when I was cammed/Paxton making over 500whp I shoulda stopped there. Live and learn though.
YellowRoush
Houston,Tx
But I've asked plenty of people, shops and people with 3vs and even dealerships and no one knows, I would really like to know if anyone on here can shed ANY light on what this cars deal is.
Aesthetics28
That's what I have now with 4.10z :(
bcb06gt
Mandeville, LA
When did this start? Was the car running perfect before returning to N/A? Did it ever run good since back to N/A?
YellowRoush
Houston,Tx
Car was built with a turbo stock heads and cams and a 6060
Put the motor that I took out of it back in that was running 100% fine when I took it out, the factory heads and cams that were on the car when I bought it so its 100% stock motor from when I got it same parts and everything. Once put back it just ran like shit. I've replaced all the parts I mentioned in the first post so idk why it's running so bad. And the trans is a factory 3650 with a factory clutch and driveshaft
KatoS197
Addison, TX
My car would idle rough and lower than normal. Even died twice. Didn't throw any codes and it felt like it was missing. After compression tests, checking the plugs, cleaning the MAF and TB, etc., it turned out that the seal around the stock paper filter had been torn somehow and it was causing turbulent air to pass through the intake. Not saying this is your issue, but sometimes it can be something you'd never suspect. If you've got a factory air box, check the filter and make sure it's sealed around the edges.
Mach2burnout
05 Redfire GT
Central Louisiana
You didn't let any wiring get between the bell housing and the engine block by chance?
Just a shot in the dark but it happens
Sent from iPhone
gray06gt
So your p1298 code is your idm(injector drive module) module I would start there. Also check the voltage of the battery cause it can cause that code if the voltage is too low
gray06gt
The 2196 code is a 02 sensor code but it can be caused by the 1298 code
YellowRoush
Houston,Tx
Can you link me to that? I've done tons of research for years and I've never heard of that part before. Couldn't find any info when I did a quick google search.
