Department Of Boost
Alpha Geek
- Joined
- May 26, 2010
- Posts
- 8,808
- Reaction score
- 32
Thanks guys!!!!
here is my DOB
the best part about the DOB kit is you don't have to buy a entire kit. you can a entry level kit and source the rest used.
I bought a entry kit, bought used parts from several people. traded labor for parts. I built my entire forged motor including the DOB intake for less than 5K.
everything fits under the stock hood.
I have a BMR 1/2" drop K member. I have to trim the Bullitt strut tower brace a bit by the throttle body and it will fit.
I will ask my friend where he bought the ud pulley tomorrow.
I am running the smallest sc pulley you make and a 10% overdrive innovators west 8 rib dampener.
19lbs boost on a forged motor. 650 rwhp on 93 octane.
Right now they're looking into a set of cams for my N/A quote. They had a Shelby GT with all the same N/A mods I'm looking at (almost -- they had a BBK TB, diff LTs, muffler deletes) that pulled 351 RWHP on the dyno. They were running Comp Camps Stage II NSR and said they were really similar to the the FRPP Hot Rods -- but they mentioned that both have a tendency to lose a little bit in the low end and finally gain above 3500. Since I'm primarily driving stop light to stop light, they're trying to track down a customer than ran a different set of cams --gained power throughout the range, especially down low.
I have just done the NA mods..
cars got, headers, full exhaust, pullies, ford racing intake manifold, hot rod cams, 4.10's etc. I am not impressed for the money spent, it looks tits and sounds awesome but that 350hp isn't the change you would expect and any cams that increase high rpm power will lose down low.
Im the same as you and do a lot of city driving, i'm planning on doing a DOB kit this winter/next spring, doing the work myself and tune with Lito.
In regards to the roush vs dob, the dob is a great piece of kit and can end up a significantly better package depending on how you build it but if you are planning on sticking with a shop that does a lot of cookie cutter kits and tunes them it may cost you less in the long run to go with what they recommend. My friend just did a Dob kit and the local shop spent hours longer on both install and tuning resulting in a huge labor bill
Where did you source the UD alternator pulley at? That's a good idea with that alternator. They don't like high RPM's.
What's the pulley combo/boost/hp?
I talked with my friend today about the UD pulley.
he is 80% sure it was from metco. if it wasn't from them then it was from billet pro shop.
Really? I'd be going from 289 RWHP to 350 --- you'd think the 60 RWHP bump would be pretty significant (hell, the 35 from the stock 255 was). Then again, torque is what turns the wheels and the car they were talking about only saw 313 FT-LBS at the wheels, which would only be a 30 ft-lb jump from the ~285 I'm making now.
Thanks guys!!!!
What makes a DOB kit different than a regular Whipple kit? just wondering? I'll be doing either a bottom end forged this winter on my engine or going to purchase the Ford racing M-6009-B53 engine and sell the Vortech with Chrage cool and purchase a DOB or Whipple or maybe a kenne Bell.any info would be appreciated.
I know I can definately feel a difference. Before the headers, cams & tune I would chirp the 1-2 shift and the car felt somewhat quick. Now I screeeech the 1-2 shift and the car feels much faster not to mention sounding bad ass!
I considered boost before I bought the NA mods but when I factored in not only the cost of the supercharger but also upgrading the transmission, clutch, rods and possibly even the rearend, I decided it was just more then I would want to invest.
I'm happy with the NA setup. If I get bored enough I can always spray a small shot of n20 (75-100). But more likely I'll just enjoy what I have for what it is until a 5.0 comes along.
