SNKPWR
Lake St. Louis, MO
Made this:
Look like this:
And loaed stock tune, so hopefully monitors set up quickly so I can get emissions done for two years
GallopingFord
I'm Cam - Mr. Indecisive
Northern Virginia
Installed new oil pan along with some fresh oil, tightened the UCA and gave it a bath. Now taking it out for an evening cruise.
5tangiac.0
Houston, TX
Put on some bmr lca relo brackets. Wow. What a difference. I lowered first with frpp shocks/p springs, then did steeda lcas. My car actually felt worse after installing the lcas. The rear end feels a lot more planted all around.
o2sys
Installed the grill.
Riptide
Will work for Mustang.
Montucky
Stock wheels with all seasons going back on today. Darn winter season. :p
I wish there was a way to flash one value in the ECM to change tire rpm without reloading the entire tune and resetting the rest of it.
There is. Just have a tune written with the other tire rpms. You will still have to load a tune but it won't be as time consuming as doing it via the options option. Your tuner should be able to whip it out in fairly easy. It would be worth it to ask imo.
BLKBULLITT
Calgary, Canada
Washed it up today. Bought hot rod cams for a steal of a deal ($250!) that were never used but been sitting a while.
And tomorrow waxing the car and putting it away for winter
weather man
Persistance Is A Bitch
MN
Great deal on the hotrods!
bujeezus
Alabama
didn't do anything to the bullitt but finally go a good, low profile jack so i can do things to it in the future. the little walmart special jack i've been using was ridiculous.
