DVEST8R's new build. TT 3V In progress
DVEST8R
Starting the new build and super excited. Last year on a rod and piston .020 over motor i was able to use a on3 kit and on3 78mm turbo to go 5.83 to the 1/8 @ a best of 119mph. This year id like to thank and welcome aboard the S&H performance crew Bobby and Jeremy as they have sponsored me. We plan to put up some insane track numbers with the twin kit. Gonna be using big bore boss block combo this season as well. Forged stock stroke crank, forged rods ,diamond pistons,arp everything , cometics and total seal rings while displacing 304 ci and 12:1 compression. Re using my heads and custom turbo cams.
DVEST8R
twin 6262s
Northwest Subs Chicago
Alright!! been waiting for a Big Bore Boss/ Big Boost build to start. Congrats on your last year numbers, this new setup should be wicked fast. If you could also list the actual parts used in the engine build with part #s, I wouldn't mind copying this engine setup if it works out with the Compression for a centri build. Did you make your own engine brackets plates or purchase the the FRRP ones, the price for those plates seems high.
Good luck...
DVEST8R
one side on!
Dark_horse
KC MO
Hell yeah Ed... Can't wait to put a whoopin on ya, cough, see it finished!!!
JoshK
Modder AKA Fuel
Nebraska
You have a 4R right Ed? Anything need adjusting on this kit to fit around that?
DVEST8R
yea it will need some work to fit properly but will be worth it
05stroker
Never enough power guy!
Bullard Tx.
Didn't Mike already fit this kit with the 4R? Or is this something different?
JoshK
Modder AKA Fuel
Nebraska
I was wondering if this exact it would fit or need to be modified any. I know they have made them fit before, just wasn't sure if they changed the jigs on new kits to make them fit without having to be modified.
TexasBlownV8
Formerly TexasBlownV6
Central Texas
one side on!
Yup, looks familiar! ..but, watch out for room for the inlet coupler to clear that frame member!
Was any 'notching' of the trans case needed? Probably not, but just wondering.
DEFINITELY! ..wait for that first 'holy shit!' moment when you're behind the wheel..priceless!
Yes I did. Having them able to fab up things right there on the spot is fantastic!
This will be an interesting and similar setup to up to mine.
The 4r makes it all tight, but there is some room to fit things, although a little differently than in a normal manual setup. It's not that much different, just a little tweaking here and there, and it'll be fine.
The wastegate positions probably gave me more issues than anything, trying to squeeze them in and clear things, and not change their location nor angle much on the pipes.
I'm curious how things will be set up and tweaked :word:
