I added this exact line set to my Mustang two days ago. The hardest thing is simply accessing the connections. The right angle one at the slave cylinder is easiest with a long, right angle pick. I removed this piece, and installed it on to the new line set, and lowered into place from the top, then crawled under the car and attached the right angle piece to the slave cylinder. As for the top connection, I found unbolting the AC accumulator (I think that's what it it) and sliding it out of the way helpful. Use duct tape on the holes in the sheet metal so if you drop the clip it does mean you remove the fender (don't ask why...). Lastly, you really have to push the connector into the fitting at the firewall, and a nice long handle set of pliers is helpful. If you don't get it in all the way the clip may still seem to set and once you press the brake pedal, brake fluid shoots everywhere (don't ask why here either...). I can't really tell much difference, but I'm still getting used to the new T56 and crate motor, so it's hard to tell. Good Luck!
