loots06
Is sounds like it's hitting on 4 cylinders and the other 4 it's not. I'm checking compression now.
If your timing was out on one side I would think that you would be getting different compression from the driver vs the passenger side....So you are for sure getting spark on the driver side?
stupid question, but have you reloaded the tune after fixing the ground? Is it throwing any codes?
Also something I have seen allot is the 02 sensor wires can be crossed and it will run like shit until it goes into closed loop fault
200 on the passenger side 180 on the driver side.
Yeah then your timing is probably off....that sucks!![]()
Could this be a timing issue? It's only running on 4 cylinders, it's got spark and fuel on the driver side but it's not firing. I'm getting ready to do a compression test.
The power to the COPs comes from the same source, have you done any work to the factory harness?
The variances in you compression test could be from one bank being wet with fuel. Is there spark from the COPs on both banks?
If you think the cam timing is off there is only one thing to do, pull the front cover and check it out.
The firing is going off the crank sensor not the cam sensor so it should spark regardless of cam shouldnt it?
and i believe the PCM uses the signal from the cam position sensor, to know when to activate the fuel injectors.
Ok, you can run an engine with no cam sensors at all.
Cam sensors are used to determine where the cam is at for startup but timing is determined via crank sensor only.
Sorry for the question but how you know is running only on those cylinders?
It is possible to degree the cams in "perfectly" while one is 180 degrees out, which would essentially result in the motor being a 4 cylinder, or at least only running on 4 cylinders. You can check this by pulling both valve covers, get #1 at TDC on the compression stroke then look at the valves on #6, they should be on overlap, opposite. You will need to pull the valve covers anyway to remove the front cover, might as well check this first.
