loots06
I’ve followed many builds on this forum and I’ve finally decided to take the plunge and pursue a build of my own. I’ve been wanting to do this build for a while but sometimes there are just more important things to consider. My build will be what most would consider a budget build. The overall goal would be to get to close to 600rwhp but truth be told I just a strong reliable motor for some spirited driving, autocross and an occasional trip to the track, about 2 hours away. I plan on keeping my current motor fully intact for the unknown.
My build will consist of a 4.6 block, bored .020 with ARP main studs and side bolts. I bought the block from a fellow forum member and King of the Rednecks Sportinawoody, http://www.s197forum.com/forum/showthread.php?t=119521
I’ll be using Wiseco K0075X2 - 4.6L 3V Piston / Ring Kit -6cc Dish. I placed my order with Modular Head Shop. They should arrive in about 2 weeks. Specs below.
Bore
3.572"
Compression Height
1.220"
Dish Volume
-6cc
Top Ring Down
.300"
Valve Pockets
3V
Wrist Pin
S747 .866" x 2.250"
Wrist Pin Material
4130 Chrome Moly
Piston Rings
3572GNX (Included)
These Pistons are an In-Board Forging, Strutted Skirt design capable of handling boost and / or nitrous. Some of their features are a .300" Down Top Ring, .155" Thick Skirts and Struts and Wiseco Armour-Glide Skirt Coating. Rings are included in the kit, GNX piston ring set which uses a gas nitrided steel top ring and Napier 2nd Ring with a 3 piece oil ring. The Steel top ring is capable of withstanding large amounts of Boost and / or Nitrous, while the Napier 2nd ring helps with oilcontrol.These pistons are designed for use with 3V cylinder heads and have valve pockets for both Intake and exhaust valves for use with aggressive Camshafts.
I’ll be using Boss connecting rods, part number CR3Z-6200-A, that I ordered to Steve at Tasca. The rods arrived last week! I’ll be using at stock 4.6 crank. I’ll also be using the GT5000 oil pump, slightly modified, and TTY head bolts.
Stock heads, I believe I have a lead on a set. The heads will have some work done to freshen them up. I figured since I’ll be building the motor and freshening up the heads that I’ll change the cams, springs if needed, retainers ect. I want something with a nice sound and will give me some good gains. I’m looking at the 127550’s but I’m still undecided. If someone could help me decide that would be great. Finally, I’ll also be changing from a 6 rib to an 8 rib belt conversion, because why not.
I'll keep adding to the list as I go.
Block, $650 plus shipping
Pistons, $780
GT500 Oil pump w/billet gears, $295
Head changing kit, $80
Stock Crank, free
Heads, $400
Bore
3.572"
Compression Height
1.220"
Dish Volume
-6cc
Top Ring Down
.300"
Valve Pockets
3V
Wrist Pin
S747 .866" x 2.250"
Wrist Pin Material
4130 Chrome Moly
Piston Rings
3572GNX (Included)
Pistons, $780
Stock Crank, free
Heads, $400
