3v Budget Build
loots06
Monterey CA
Is sounds like it's hitting on 4 cylinders and the other 4 it's not. I'm checking compression now.
loots06
Monterey CA
I'm not particularly happy right now the engine builder said when the motor was picked up that it was timed correctly. It's apparent now that it is not. Only the passenger side is firing, compression is good, spark and fuel are good on the driver side. The only thing it could be is timing. The builder said he guaranteed the timing was perfect I am completely frustrated.
wildbillcody
tennessee
If your timing was out on one side I would think that you would be getting different compression from the driver vs the passenger side....So you are for sure getting spark on the driver side?
wildbillcody
tennessee
Also something I have seen allot is the 02 sensor wires can be crossed and it will run like shit until it goes into closed loop fault
loots06
Monterey CA
200 on the passenger side 180 on the driver side. Checked the spark it's good.
stupid question, but have you reloaded the tune after fixing the ground? Is it throwing any codes?
I was really excited when I found the broken ground, fixed it still nothing. Reloaded the tune and it will start if you give it gas runs like shit but still no codes.
I'll check but don't think that's an issue.
05stroker
Never enough power guy!
Bullard Tx.
Could this be a timing issue? It's only running on 4 cylinders, it's got spark and fuel on the driver side but it's not firing. I'm getting ready to do a compression test.
The power to the COPs comes from the same source, have you done any work to the factory harness?
The variances in you compression test could be from one bank being wet with fuel. Is there spark from the COPs on both banks?
05stroker
Bullard Tx.
If you think the cam timing is off there is only one thing to do, pull the front cover and check it out.
loots06
Monterey CA
It did take a little bit to build to the 180, not the case on the passenger side. No work on the factory harness at all. And yes there is spark in both banks but the driver side is not firing.
We've checked everything else that's the only thing it could be.
loots06
Monterey CA
What else could cause the driver side, bank 2, to not fire. If it's firing on the wrong stroke then it's a timing issue correct.
Wes06
The firing is going off the crank sensor not the cam sensor so it should spark regardless of cam shouldnt it?
hammeron
and i believe the PCM uses the signal from the cam position sensor, to know when to activate the fuel injectors.
loots06
Monterey CA
Yes but if it's firing on the compression stroke then nothing correct.
Correct, then it's a timing issue or something else. I've ruled out spark, fuel and it's making compression...
lito
Caracas, Venezuela
Ok, you can run an engine with no cam sensors at all.
Cam sensors are used to determine where the cam is at for startup but timing is determined via crank sensor only.
Sorry for the question but how you know is running only on those cylinders?
swflastang05
Back for More
N. Ft. Myers, FL
It is possible to degree the cams in "perfectly" while one is 180 degrees out, which would essentially result in the motor being a 4 cylinder, or at least only running on 4 cylinders. You can check this by pulling both valve covers, get #1 at TDC on the compression stroke then look at the valves on #6, they should be on overlap, opposite. You will need to pull the valve covers anyway to remove the front cover, might as well check this first.
loots06
Monterey CA
When it started the passengers side was hot and the driver side was completely cold.
I'll pull the vavle covers and check this but I can't touch the car until next Wednesday.
travelers
Eastern Pa
As everyone knows you need fuel, spark, timing and O2 to make an engine run. Now you already know you have fuel and spark so the only thing left is the timing of the O2. I would definitely say timing. Do the 3Vs have a color coded link on the timing chains like the coyotes do?
