rojizostang
i love my cams
I posted a link to ebay where I purchased the upgraded gt500 intercooler pump. I decided to start a new thread, thinking not everyone is looking at it.
On the ebay listing, the instructions for the newer pumps say to jumper pins 3 and 4 and apply 12v there, and then ground pin1 for the pump to run at full speed.
the harness I bought only utilizes pins 1 and 4.
Can anyone confirm that the pumps indeed run at full speed only when jumpering out 3 and 4 and grounding 1?
here are the links to ebay where the instructions for the pump is
http://www.ebay.com/itm/301868988494?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
this is the jumper I bought, it appears this won't run the pump at full capacity
http://www.ebay.com/itm/222070744960?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
this harness should allow the jumper instead and run the pump at full speed:
http://www.tascaparts.com/oe-ford/cu2z14s411aya
for anyone reading this post, I edited it several times before getting all the information in here. Basically, anyone using the newer pump, if they're only using pins 1 and 4, they probably aren't utilizing the pump at full speed.
can anyone confirm the proper wiring to run the pump at full speed?
