Bullitt 3309
I just have not heard these cams lope yet....
I thought you had the Boss cams(high lift)
These are the low lift version of the CJ cams that lope like Comp Stage3 n/a cams
Do you think they helped out at all? I ordered the cams and boss springs last night.sorry i have the cheap high lift cam
Here are the differences:
M-6550-M50BEXH = 13mm/290 duration, upgrade for the Boss heads, grinding needed to fit gt heads, $715.
M-6550-M50BR = 13mm/263 duration, production Boss, possible grinding to fit gt heads, $100.
M-6550-M50GTE = 11mm/290 duration, upgrade for GT heads, no grinding required, $275.
so if one were to do the actual CJ cams on a stock Coyote, do you just need to swap heads and springs (if you don't want to go the grinding route)?
I have them. If you are swapping cams you might as well do them.
