rocky61201
I'm getting tired of my heater coolant pipe leaking/dripping into the valley of my 3v. I've replaced the tiny rubber O-rings twice and it just won't seal.
I know I've read in some supercharger install manuals that require you to cut/remove that pipe and replace it with a hose/worm clamps. I want to perform this mod and be done with it.
Has anybody out there done this and if so, do you remember the diameter of the heater hose/worm clamps you used and any other parts needed? I prefer to only have to run to the parts store 1 time before I start removing everything to get at that damn pipe. FYI - its the pipe in the valley of the engine block that feeds into the back of the block directly behind the water pump.
