Joe88xj
I am putting a set of aftermarket gauges in my 06 GT wondering what best way/location is to install temp sensor? Thanks in advance guys!
Joe
Joe
Yes autometer cobaltHave you already purchased the gauges?
I used the glowshift adapter, as well, on my F150. Works great.An splice in adaptor in the upper radiator hose is one of the easiest ways, I run the glowshift one. You could drill and tap the coolant crossover as well.
There is a location on the driver's side of the block. I put mine there. It is about 3/4 ways back from the front.
This is where I put mine as well.There is a location on the driver's side of the block. I put mine there. It is about 3/4 ways back from the front.
I think I like the idea of having the sensor located in the block anybody have any reasoning for why the splice in the upper hose would be better? Is the engine hotter up at the top of the engine such that putting it on the upper radiator hose would be a more accurate reading of the engine temp??
