Be careful here. You still have to move those pistons enough to take up the running pad to rotor clearances and any pad compressibility, and a larger total piston area will need more fluid in order to do this. Ultimately, this means you get a slightly longer pedal using the same MC.
The problem is the GT's (non-Brembos) start with long travel squishy brakes .
I took mine in the first month complaining, and they said this is how they are.
Now that I finally have a pedal (3 month nightmare of various types of bleeders
and $1100 bi-dir scan tool) after the front Brembos, it is significantly worse
in pedal travel. Not even really sure what I did right to get a pedal at all, finally.
Even when the brakes seem to work great, if you push hard enough when stopped,
pedal goes down and hits a hard stop. I drove an 18 PP that did the same thing. I
couldn't believe that Ford was OK with that, but yesterday I stumbled on a post from
6G board that said that "theirs" does the same thing (and others agreed it is normal).
I posted up on on trackmustangsonline about putting S550 PP MC in an S197.
https://trackmustangsonline.com/threads/s550-pp-master-on-s197.14230/
I couldn't get a pedal when I had that MC on (couldn't get a pedal with orig MC
either, for quite some time), so really can not comment on pedal feel with that MC.
But I do feel these cars need a larger MC to get a brake feel that won't make me
think there is something wrong with the brakes, every time I drive it. Go drive any new
Fusion and you will see what I am talking about. I had an AWD 4 cyl eco and now a Sport
and they both have brakes that work RIGHT NOW, which I highly prefer.
