Dyno sheets and numbers
jacobychrisa
I would love to get a lito tune. But how do you get ahold of him?
Sent from my SM-N960U using Tapatalk
Unexplodedcow
They have a new revision now that works and fits great
Good to know, especially as the cars age, and the plastic would fail. I'd expect the 2009 and 2010 years to especially have fun since the intakes have the CMP shaft built into them, and require additional seals.
As an aside, Jegs also makes one under their own name, but suspiciously similar?
https://www.jegs.com/i/JEGS/555/513058/10002/-1
dazed1
Stillwater, Minnesota
I have a 2009 Bullitt, ford performance intake, BBK long tubes, BBK high flow catted x-pipe, full Borla ATAK cat back exhaust, BBK under pullys, Ford upgraded throttle body and last a 93 octane Blow by Racing tune.
Unmodded this engine was rated at 320hp at the crank. With the mods last Dyno showed 345hp, 330 torque UNCORRECTED. It shows 330/322 corrected.
Still has stock 3.73 rear gears and yes that old speedo needle will go past the last marks on the speedo just beffbe you shft into 5th gear. Great car!
jacobychrisa
So we should be pretty close then huh? Without my cats and with the cams I could be a little higher
ghunt81
New parts on old junk!
Clarksburg, WV
I'm surprised the PO of your car installed muthr thumprs and didn't even bother to swap out the exhaust manifolds. I would imagine that thing was kind of a dog at low RPM's.
tjm73
of Omicron Persei 8
Rush, NY
I've got an 08 GT.
Those wheels look really good on that body style. Did they require spacers?
jacobychrisa
Oh man it is. Until about 3500 it's bad. Just got the headers yesterday and starting the installation tomorrow night
ghunt81
Clarksburg, WV
S550 wheels will go right on without spacers if you have standard brakes, however they won't clear Brembos without a spacer.
tjm73
of Omicron Persei 8
Rush, NY
The wheels on your car look awesome too. LOL!!
