When to rebuild Paxton 2200SL
Gruca
World's Slowest 3v Owner
Peotone IL
How do you know when the head units need a rebuild? Mine runs, isn’t terribly noisy, but when datalogging, my load and Maf lbs keep decreasing over time. I have a 3.48 pulley on it currently and load peaks around 1.55. It used to peak around 2.10. I also used to peg the Maf sensor, and now I do not. I’m assuming it’s due to decreased air flow? My boost gauge still reads 13psi around 7,500. Not sure what else would cause the lack of airflow at the Maf.
Gruca
Peotone IL
dirty air filter?
You know, I thought about that after posting. I did have a red reusable one on there when I datalogged. I recently put a paper version of it in. I’ll datalog it again and see what happens. Good call.
Gruca
Peotone IL
dirty air filter?
Well that was definitely it. The paper filter got my load and MAF flow rate back to what I would expect.
The weather was crappy both times I data logged. A little cooler the second day, but much more humid.
