Looking for ported heads.
myystanng
I’m looking for ported heads for my 3v.
Had an issue on my livernois stage 3 and at least one head is bad.
Let me know what you guys have
myystanng
Thanks for the response man!
msvela448
I have a set of stock 3v heads (bare) I would sell that you could have worked over. They have a couple of broken exhaust studs, but nothing a machine shop couldn't take care of. I have the stock retainers and keepers and all the valves except 8 intakes that were bad (all 8 exhaust and the other 8 intakes are good). I have two sets of stock springs, and the stock cams too, but I doubt you want those. PM me if you want more info.
Sent from my SM-N975U using Tapatalk
myystanng
Thank you for the offer, but I have another set of stock heads if I go that route
08MustangDude
Resident Fuktard
Buying someone else's ported heads won't match your intake, or your
exhaust headers. You port your heads and intake to match the parts
so there are no ledges if the ports on the used one you bought don't
match with your intake manifold or exhaust headers.
I the exhaust sides are too large, there will be a ledge at the header, and
mess up the exhaust flow.
If one or two of the intake sides are smaller than your intake, then you
have a ledge that interferes with air-flow.
Porting should match your components, not someone else's.
POLISH the exhaust sides, not the intake.
myystanng
Thank man, I’ll hit him up!
Waakeeen
Since were talking about heads does anyone know if 2010 stock heads fit a 2006? I know both are 3v but I don’t know if I’m missing something.
msvela448
Yes they will fit.. I have a set of 2010 3v heads on my 2007. New-style spark plugs is all you'll need.
Waakeeen
Awesome! Also there wasn’t any clearance issue with the spark plug and piston?
myystanng
They bolt right up and has the better plugs!
msvela448
The coils are also interchangeable. I used the old coils in the new heads for a long time.
