I have an "09 GT Coupe and I believe that my drain comes from the Shaker 500 not shutting off the sub-woofers. As long as I shut off the stereo before I shut down the engine -I'm OK. My $.02.
All good there voltage wise, and battery is fully charged (12.7Thanks for all your input, I had it on my battery charger/maintainer this morning for 2.75 hours, charger read 99% and battery13.04 volts when I took it off. Took it out a drive and the battery read 12.71 volts when I came back. The last time I checked the charging system it read 14.00 volts at the battery. What do think?
Never heard of a battery storage disable fuse, nor was ever aware of it. So what exactly is it and what is it designed for?My 2008 BULLITT#5430 also has the active anti-theft. I took a tip from the Factory Service Manuals — the battery storage disable fuse (10 amp) is located at position #43 under the fuse box lid.
Just pull it any time you don’t want to drain the battery.
