1950StangJump$
- Joined
- Apr 1, 2010
- Posts
- 968
- Reaction score
- 108
So, got it recharged .... I think.
I put a new dryer on. Then used the pump, put vacuum on it, which held for an hour. So, no leaks.
Then turned the pump back on and ran for an hour to remove moisture.
On to the Freon. The sticker said it holds 1.625 lbs (26 oz). So, I added 2ish oz of oil and expected to be able to fit in 24 oz of Freon.
Got one 12oz can in. But, the second stalled at about half a can, and it wouldn't take more no matter how I manipulated it. I wonder if the aftermarket condenser held less than stock.
When I gave up, the air coming out of the vent was mid-40s then ... after the car had been idling an hour in a 95+ degree garage. Sound right?
The compressor would go long periods without cycling off and on, which I think is how it is supposed to be.
