Modifying an unknown tune without the stock tune.
SmallBlock850
Pensacola, FL
I recently bought a 2005 GT and it has quite a few mods done to it.
Cam swap, rear-end, Hurst speed shifter, headers and full exhaust.
I was hoping to grab a tuner and update the settings for the rear-end so I can calibrate the speedometer.
The problem is I don't have the stock tune and I'm not sure if the new programmers are capable of downloading the modified tune so I can back it up in case something was to go awry. Or heck, even if they're capable of downloading a tune that doesn't match the device.
It's definitely not worth bricking the car to fix the speedometer.
What are my options?
Hp tuners is the only option to read, modify, and reflash current tune.
Diablosport InTune can modify "stock" tune if it can read it. It may not.
Pay Ford dealer to set gears/tires in VID block. This will only work if the tune is using the vid block for gears. And they may 'accidentally' reflash to stock.
SmallBlock850
Pensacola, FL
That's my worry is having the tune flashed back to stock.
With the cam setup, CAI, headers, I presume it's going to run extremely lean and\or set off the knock sensors.
I was hoping maybe I could find the previous owner on one of these forums.
If someone recognizes the car, please let me know.
The cams aren't overly aggressive, but it definitely has some lope to it. (don't mind the exhaust rattle, I fixed that already)
If you get e new tuner you can use your current tune as the stock tune. When I switched from Diablo to SCT, I used my BAMA tune in the car as my stock tune for the SCT.
Wont work with SCT. Yes, it will save any tune as stock,but there aint shit you can do to it.
The only real option I see for the OP is to find a shop who tunes with HP. And just have the gears fixed. And can keep the current tune.
I take it you did not receive a tuner with the car, any chance you can track down the previous owner, he could have those files saved to a PC?
SmallBlock850
Pensacola, FL
Negative, the tuner wasn't included unfortunately.
I'm trying to find out from the guy I bought it from. He got it from an auction.
Hopefully that'll pan out.
SmallBlock850
Pensacola, FL
This is the route I'll likely take.
There's a solid tuner scene around here so I'll reach out to some of them. Thank you!
SmallBlock850
Pensacola, FL
So FORscan, that application sounds promising.
I should be able to download all my tune\module data for a back, then modify the wheel size \ rear gear ratio. Has anyone used that before?
I do not believe Forscan can modify gear ratio on the 05-09(10?)s.
SmallBlock850
Pensacola, FL
Good question, I've been trying to confirm that unsuccessfully so far.
I believe the car is compatible but idk to what extent.
I'm going to link up to it and see what options are shown.
pass1over
I like it LOW
Trenton, FL
previous owner could of sold car with tuner but it got nicked from the car at some point. Either at the dealership he traded it in at, or the auction that sold it. I bet there were a lot of people in and out of that car before current owner took possession of it.
But I agree, what a headache.
Earl D Davis
I see tuners for sale on Market place almost every day. When I ask if they have been un-married from the previous car, I get either HUH, or some BS about the car being totaled and when I tell them it will cost $150 to send it in and be un-married, the price will go from $100 to $35. Obviously, it is stolen. This is a sad fact.
Derf08
Not a fact.
I owned my 2008 since new until it got totaled in 2022. It was tuned. When my insurance company paid it out, i gave them the second key. I asked if they needed/wanted the tuner they said no.
I have the married tuner. It's a SCT3 (bought it in 2010). I will probably scrap it because it's not worth having it unlocked.
Forty61
Dallas, TX
Not a fact.
No need for the tuner on a car that is headed to the scrap yard. I’d wager a lot of people do steal them thinking it’s an easy paycheck to stick it online, it’s only people like us who use them that know they’re married to the car in the first place.
JEWC_Motorsports
S197 Junkie
Thats not completely true. You can modify the tune with a SCT handheld device if its unlocked. Some tuners do leave certain things unlocked and some dont.
Modify stock tune with handheld, yes you can.
Taking the backup file and opening it in Advantage PRP, no. Only HP tuners can download and open the actual tune in the pcm.
And its one or the other with SCT, custom tunes, or preloaded tunes /modify stock tune. Cannot have both enabled on the X4. Yes, I have tried.
