Watts link / suspension questions
Earthworm
Ct
Hello all,
2007 Mustang GT
After current work, no more clunkin, accelerates better, but is a little floaty/bouncy. I want the car to be less bouncy and feel planted. Handle curves better.
All recently installed new:
gt500 A arms w/ bjs and bushings
stock height struts
Rear stock height shocks
Front sway bar end links
Poly front sway bar bushings
Inner/outter tie rods
Do I need to get an alignment if I install a watts link?
Do I need an aftermarket sway bar to accompany the watts link?
Would weld in subframe connectors improve handling?
Any recommendations?
Thank you!!!
DieHarder
Hello all,
2007 Mustang GT
stock height struts
Thank you!!!
Replace the stock struts/shocks with something decent - try Bilstein B-6. Also recommend replacing your springs with Rousch while you're at it. Ride is still compliant; just firmer/more composed. If you do lower it you'll need an adjustable panhard bar to recenter the rear end.
AHaze
Edmonton, AB
Biggest improvement I experienced to the stock floaty ride was replacing the stock rear shocks with Bilsteins. Obviously, the struts should be done as well but I couldn't believe the difference after doing just the rears.
Earthworm
Ct
I replaced all the struts and shocks with stock height parts.
I was thinking either rear LCAs, UCA and rear sway bar or spring for the watts bar. The videos make the UCA look not too bad, but I heard read differently.
Down the road when I get use out of the current suspension I will look into the mentioned shocks from above.
JC SSP
FL
I second the motion... you cannot go wrong with Bilstein's.
Earthworm
Ct
I did the rear shocks first and immediately noticed the car got up and moved forward, big improvement of acceleration. I think I am going to go with the bmr non-adj UCA, new mount and LCA. See how that feels. Had them on my old 2006 and felt an improvement then. People have mixed opinions on the watts link. So I don’t want to spend 900 yet to find out
Gabe
Whippled Coyote
What brand shocks and struts did you go with?
JC SSP
FL
You read my mind... go play lottery!
I am curious too what are "I replaced all the struts and shocks with stock height parts."
Earthworm
Ct
They were made by TRQ. Put them in last weekend
