GriffX
Rural Germany
The Bullitt or FR intake really gets the outside air. I was curious and did a logfile run to look at this.
EBABlacknChrome
Michigan
Finished my GT500 dual fuel pump upgrade, also did a wire upgrade on while there, cleaned up some wiring under the hood, installed 47lb injectors, and started tuning with Lito. It's been an adventure since April when I started it. All the wiring coaching has come from Casey (rocketcarx). I have learned a lot over the last 2 wiring projects. Wireeverything.com is the way to go. I like clean and neat, and this was the ticket.
Sent from my SM-G996U using Tapatalk
crjackson
Midgard
Feel free to come and visit me, and upgrade my fuel delivery system too. All the free beer and BBQ you want. I have 2 spare guest rooms, take your pick, or bring the RV. Free hook-up, bring your tools. ;)
Miker
USA
Resized_Resized_20230810_084056.jpeg 20230810_091107.jpg Changed the oil and filter for the first time. It was done just before I bought it. Was setup to change out the TR3650 fluid but I checked it with a bent q-tip and it was bright red and smelled fresh. So buttoned that back up as it shifts like butter. And just as I was finishing cleaning up the mailman dropped off a Diablo Intune II that I picked up on FB marketplace from a very nice guy in TN. I had added 10 gallons of 91 octane to 87 octane I had in the car a week ago and my tank is still half full. So I didn't want to install the 91 octane tune yet. I installed the 87 octane canned tune. I was quite surprised by how much snappier the car was. Gone was the lag it had in the lower rpms. Also the car seemed more powerful throughout the rpm range. I am going to run this tank out and then install the 91 octane tune but honestly the 87 octane tune added exactly what I was looking for.
AHaze
Edmonton, AB
Welded up some stainless lines to replace the mess of rubber fuel line I had going to my catch can. Replaced the repurposed Motorcraft PCV valve with a nice aluminum check valve in the setup as well. Of course, as soon as I was done, I saw several things I wish I had done differently but whatever.
View media item 8856
Candy10
Middle-of-Nowhere, Texas
Finally got my 130mm mono TB and new MAF housing/sensor installed, and tune redone. As for numbers, this gets a bit confusing, I almost feel like I should make it its own post for discussion. Two completely different dynos, so hard to say exactly what I gained. But the ass-dyno says we gained quite a bit.
I’ve no complaints, except the MAF Kenne Bell sold me showed 4.86v while data logging, max is 5v. Next round of upgrades, this could be a problem. Always something
Gladams
Oak Grove, Missouri
But my boomba racing trans mount back in. Took it out when I had the stock shifter in, had a bit too much NVH. I have the Barton Hybrid 3 transmission mounted and I was surprised that there wasn’t any NVH at all and shifts are real quick and crisp. Wish I would have put it back in when we installed the shifter. Lesson learned. Thanks.
Gabe
Whippled Coyote
Wife's Shelby: replaced the old NGK TR6 spark plugs with new iridium TR7XI plugs, gapped to . 028" and cleaned the throttle body. Old plugs had opened up to about . 031-.032" over the last few years they were in there (probably about 3k-5k miles at most).
Gabe
Whippled Coyote
Did some diagnostics on my 40A Kenne Bell boost-a-pump.
Installed 8 years ago, now I'm getting weird voltage readings out of it. Sometimes it's putting out 14.8, sometimes 15.x, sometimes 16.3-16.6V.
This is measured at the relay terminals, right there by the FPDM.
So does this mean that the BAP is going bad?
I had a couple issues with the car not starting over the last couple months, this is how this whole testing started.
The first time it happened I bypassed the BAP and the car started, allowed me to putt-putt it home. Got it home, removed the bypass, it wouldn't start, replaced the relay and it started. So I thought it was a bad relay, but with the new relay the car again didn't start about a month later.
Today I re-installed the relay that I thought was bad, and the car started. WTF ?
I don't hear of them going bad often, but I guess everything can fail eventually.
Miker
USA
1a1.jpg 20230906_163736.jpg 20230906_163748.jpg Found the unfindable. I think this came as part of a handling kit that Ford sold back in the day. Also sold as a STB for the V6. Same as the Bullitt brace but black. Clears the plenum cover easily. Does push on the hood insulation but the hood closes fine.
crjackson
Midgard
Gabe, have you contacted KB? They might be able to provide a diagnostic procedure, or even let you ship it to them for testing.
Ret
Hope, ID USA
Miker
Anyone on here can tell you I'm no mechanic. But your entry about mixing the premium with the regular gas peaked my interest. When I bought my 2012 GT convertible, I read an article that said don't mix the two octanes. My car has the Coyote engine with 412 HP. The article said don't mix the two as the computer adjusted the car to run on one or the other.
Gabe
Whippled Coyote
I have not.
I went back to the car last night, started it and checked the voltage coming out of the bap. It kept bouncing from 14.5 to 17.7, and hitting numbers all over in-between. Stopping at some for extended periods of time, but still, idling I would've thought that the voltage would be steady.
I need to run one more test, and that's too see what the voltage going in is, as well as what's coming out of it.
I have a second multimeter, just not sure it's working. Hopefully I'll be able to make a video tonight showing the 2 different voltage readings. If going in is steady and coming out is all over, that should be the definitive answer that the bap is bad
Miker
USA
Miker
I don't think that mixing octane would be a problem. It seems they would just blend and be a compromise of each because of it. I was only trying to get to where I could run the canned 91 tune on my programmer which for whatever reason was a dud. I think that tune added too much timing advance and the knock sensors were pulling it out. The car seemed very confused and at one point seemed to not pull at all. Back to the 87 tune and all is well.
crjackson
Midgard
Mixing octane hurts exactly nothing. Mid-grade octane fuel is obtained by mixing (50/50) high-octane and low-octane right at the pump.
Unless your tune is locked down to premium grade, there’s no issue.
